Page Tools
Differences
Link to this comparison view
Both sides previous revision Previous revision
plugin:llcmcpp3 [2011/07/28 18:22]
cperez
plugin:llcmcpp3 [2011/07/28 18:23] (current)
cperez
Line 3: Line 3:
 Note: LLCMCPP as been renamed as L2C. However, the plugin name has not yet been renamed. So, its name is ''​llcmcpp3''​. Note: LLCMCPP as been renamed as L2C. However, the plugin name has not yet been renamed. So, its name is ''​llcmcpp3''​.
-[[http://​hlcm.gforge.inria.fr/​l2c:​about|L2C]] a Software Component Model targeted at use-cases where overhead matters such as High Performance Computing. The Adage plugin fully supports it.+[[http://​hlcm.gforge.inria.fr/​l2c:​about|L2C]] a software component model targeting ​use-cases where overhead matters such as High Performance Computing. The Adage plugin fully supports it.
   * single process assembly   * single process assembly
   * multi process assembly   * multi process assembly
Powered by Heliovista - Création site internet
